Red vertical lines in laptop screen help
aidenrelkoff
anyone know of how to get rid of a vertical red line on a laptop screen?
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
Replace the screen
Same happening to my laptop, but sometimes the lines disappear. BTW the lines i get are kinda blueish green
sounds like a pixel problem, you need a new screen.
Replace the screen
cant its a older laptop
Well then you can either live with it or buy a new laptop...
its for a friend that doesn't have enough money for one, all she needs it to wright documents, the private school where i work was throwing them out so i gone one
That's probably why they were throwing them out.
And she's gonna have to live with it. Nothing you can do about a broken LCD. :(
ahh kk
