MicroAtx Case Airflow
Go to solution Solved by spartaman64,
stacking fans wont improve performance by much. if its plexi or arylic glass you should be able to drill through it.
Hello all!
So i just finished putting my case together with the exception of the GPU and a 5.25" LED controller which are coming in the mail.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($247.98 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.79 @ DirectCanada)
Motherboard: ASRock Z97M OC Formula Micro ATX LGA1150 Motherboard  ($150.50 @ Vuugo)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  ($91.86 @ DirectCanada)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($139.79 @ DirectCanada)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($78.79 @ DirectCanada)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($409.99 @ Memory Express)
Case: Xigmatek Aquila MicroATX Mini Tower Case  ($79.99 @ NCIX)
Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ NCIX)
Monitor: Asus MX239H 23.0" Monitor  ($247.95 @ Vuugo)
Case Fan: BitFenix Spectre Pro 148.7 CFM 200mm  Fan  ($16.99 @ Memory Express)
Other: NZXT Hue 3 RGB Color Changing LED Controller ($39.99)
Total: $1640.61
A couple of things are bothering me:
1. This case is awesome, the PSU was a bit of a squeeze, (had to return the RM750 for a 650 to fit it in) but considering the GPU im putting in is an axial type GPU not a reference blower, the fan will be directly facing the window. I've read that MSI cards are notorious for putting a lot of heat into a case so im wonderinf if the fact that its facing a window increase the GPU temperatures by a lot to the point of throttling because I don't want that.
2. Is there any point to having the spectre pro 200mm fan in? the case comes with 1 200m fan as an intake already on the outside so i thought putting another fan in the same place on the inside would pull more air into the case but I read somewhere that stacking fans isnt really that good?
3. If It turns out that having the window heats up the GPU too much how would i go about drilling holes into the window so its not so restrictive? Is it even possible without cracking the glass?
Cheers
https://linustechtips.com/topic/225922-microatx-case-airflow/
