Will it work?
Go to solution Solved by Bogica,
It is, I use it on a cheap tablet via internet dongle (Huawei something), but you need to check if the dongle has Linux support. Depends on the type of dongle, but yes, he should get internet in hes house, it's the 21st century! :D
My father's colleague bought a tablet, Acer Iconia B1 730HD, and now he want's to connect it to internet using an internet dongle over OTG cable... I advised him to just install internet in his home (he seriously doesn't have it), but he wants to go over that dongle... Now, he tried and it won't connect...
Now, is it even possible to connect using OTG cable and internet dongle, or was i right in advising him to install internet in his home O.o
https://linustechtips.com/topic/225813-will-it-work/
do you mean wifi in his house
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093093
Depends. If the dongle has Linux support, what it doesn't look like btw, it wil work.
I don't know, since i didn't see it (i was at school...), but i think it should be a Huawei dongle, since, i think, all of the carriers here use them...
Yup, he doesn't any internet, even less wi-fi...
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093117
I see, i'll check it, when i get a hold of his tablet and that dongle (i'm busy with school...) :D Btw, i'm also from Serbia :)
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093144
Cool! :D If you need any help with it contact me via inbox on LTT, I'll leave you my skype or fb or something if you need further support. My usb dongle is from MTS Serbia and it works 100%, I'll check the model later. :)
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093164
really
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093246
Okay, but that might take a while...
really
Seriously, he only has cable, not internet, and he also doesn't have a computer/laptop... He now only has that tablet...
https://linustechtips.com/topic/225813-will-it-work/#findComment-3093287
