So im getting this error your display driver stopped working and have been recovered and my scren shotdown and turn on instantly, i have been trying to fix this error 1 year now and i tried everything its unfixible but i just want to try
do you run the card at stock settings? driver crash like that occurs when the card is not stable...if it's at stock try underclocking the card a little bit and see if it fix your problem.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
how to run it at stock options and i have never tried to overclock it
ok then, your card has become older and now she crash even at stock.
First make sure you have the latest possible version of the drivers for your card properly installed and then instal MSI afterbuner and try to lower the clockspeed of your card of about 50mhz and test.
i guess its fixed now everything i had to do is just to go to after burner and it said restart to make all gpu setting default and thats it thank you so much but can i stay in contact with you?
sure you can use the PM function if you have anymore questions.
