Just overclocked it, changed multiplier from 38-42, last night I got it to 4.4ghz but the hottest core was like 77 degrees, how does .2ghz make such a big difference? I was thinking I could get way higher than 4.6, but maybe not o.O. Maybe I need to clean my rad off, IDK if that makes a difference, haven't cleaned in like 1 month and my house is pretty dusty
It's being cooled by an h100i in push/pull with noctua-nf-f12's
https://linustechtips.com/topic/22564-decent-temps/
It's how Ivy Bridge is set up. How fast are your fans rotating on your rad?
https://linustechtips.com/topic/22564-decent-temps/#findComment-285050
1405 rpm, everything is setup with corsair link 2, the custom fan curve starts at like 600rpm and goes to 1500, but they don't reach 1500, I believe thats their max.  They top out at like 1435 according to corsair link 2
https://linustechtips.com/topic/22564-decent-temps/#findComment-285061
