will it fit?
Go to solution Solved by xox,
Yep, it will
If it does not (highly unlikely), do a little mod
hi guys, well as you know the new nvidia cards are out, so i was wondering on getting a 970 for 1080p gaming and probably 1440p, but i dont know if it will fit in my case, a thermaltake commander, so what do you guys think? will it fit?.... thats it, thanks for the help
https://linustechtips.com/topic/224745-will-it-fit/
off topic of it fitting, but on topic for your mention of 1440p
definitely look for a 1440p monitor for that card to properly use it. if you think it's not in your budget, check out the korean monitors.
I recommend checking this out: https://teksyndicate.com/news/2013/08/15/tek-syndicate-1440p-monitor-club
https://linustechtips.com/topic/224745-will-it-fit/#findComment-3078814
that sounds good i should check it in the future
Yep
thanks dude you really helped me out
https://linustechtips.com/topic/224745-will-it-fit/#findComment-3078900
