I'm thinking of building a new PC for gaming (1st time)
and this is what I've come up with so far: http://pcpartpicker.com/p/Wf4rpg
If possible can u guys recommend a motherboard, RAM and power supply?
also, if the cooling will be able to fit in the case?
Which windows OS should I run? I see others with a different version of windows 8
I'm trying to stick within a budget of US$1500, are there any ways for me to cut cost?
Thanks!
https://linustechtips.com/topic/224545-1st-time-build-help/
Thanks!
if you will be using it only for gaming you should probably go with a cheaper cpu
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3075918
The PSU is overkill. Get the 750/680watt version. The Mobo looks fine, so does the Ram.
-edit: Nearly forgot about windows. Buy a key in an online store. You can safe aroun 100$ there.
I once had one of these, now I've got this.
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3075923
Thanks!
For a gaming build, you dont need an i7, get an i5 4690k instead
Overkill PSU. For single GTX 970, you need around 500-550W PSU for it, if you plan to SLI in the future, 700-750W is enough
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3075998
I'd get the MSI Z97-GAMING 5 ATX LGA1150 Motherboard. It's the newer version of the motherboard and has MSI's updated versions of the features. Plus it's only like 20$ more so you may as well get that one instead of the out of date one....
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3076198
Wow, thanks for all the recommendations so far.
The suggestion to get the OS online was great! didn't think about that. As for the power supply, i have chosen a 750w and decided to go with stock cooling for now.
Also, I heard that 16gb of RAM was overkill for gaming so I went for 8gb.
Thanks for the suggestions on both the CPU and motherboard. however, I want to get an i7 to make room for future upgrades.
As for the mobo, upon searching for the MSI Z97-GAMING 5 ATX LGA1150 Motherboard I have come across the MSI Z97-GAMING 7 ATX LGA1150 Motherboard which one is better?
A little upgrade to some parts seemed fine due to the removal and downgrade of others
Thanks!
Right now its: http://pcpartpicker.com/p/qHptkL
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3079321
Thanks!
Well that Gaming 7 is better, and the Gaming 9 is even better than that. However, each one is in an increased price bracket which is why I suggested the Gaming 5. But in the end it's your choice whether or not you want to grab those extra features and such....
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3083317
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($338.78 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($138.99 @ NCIX US)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($349.99 @ NCIX US)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case  ($79.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Total: $1340.16
Generated by PCPartPicker 2014-09-30 10:08 EDT-0400
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3083366
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.49 @ OutletPC)
Thanks lee32uk, but is there any reasons why you went with these parts? Are these brands more reliable or something?
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3088002
No real reason apart from personal preference. They are all good brands though. Your spec in the first post is fine, although I wouldn't go for a Corsair RM psu. If you are spending that sort of money on a psu then I would go with the EVGA Supernova G2.
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3090071
I would recommend:
Seagate Barracuda 7200.14 1TB, SATA 6Gb/s (ST1000DM003)
Crucial MX100 256GB, SATA 6Gb/s (CT256MX100SSD1)
Intel Xeon E3-1231 v3, 4x 3.40GHz, Sockel 1150, boxed (BX80646E31231V3)
Crucial Ballistix Sport DIMM Kit 8GB, DDR3-1600, CL9-9-9-24 (BLS2CP4G3D1609DS1S00)
ASUS STRIX-GTX970-DC2OC-4GD5, GeForce GTX 970, 4GB GDDR5, 2x DVI, HDMI, DisplayPort (90YV07F0-M0NA00)
Gigabyte GA-H97-D3H
LG Electronics GH24NSB0 schwarz, SATA, bulk (GH24NSB0.AUAA10B)
EKL Alpenföhn Brocken ECO (84000000106)
Fractal Design Arc Midi R2 (FD-CA-ARC-R2-BL-W)
be quiet! Straight Power E10-CM 500W ATX 2.4 (E10-CM-500W/BN234)
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3090174
Also if it is just a gaming pc then you can drop down to the i5 4690K.
https://linustechtips.com/topic/224545-1st-time-build-help/#findComment-3090219
