My r9 295x2 wont turn on gpu2. i just recently got my new gaming pc and now when i fired up RivaTuner and Unigen Valley benchmark the r9 295x2 is not using both of it cores. gpu2 gets hot but it's not being utilized.
plz help me!
Try disabling ULPS
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-3075778
Where do i disable that?
Google is your friend. It has guides. I can not be bothered to write one here.
https://www.google.fi/search?q=disable+ulps&oq=disable+ulps&aqs=chrome..69i57j69i60l3.3658j0j7&sourceid=chrome&es_sm=122&ie=UTF-8
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-3075823
What is ULPS ?
If you're using MSI afterburner, there is an option to disable ULPS in settings.
If not, you have to go in the registry (run : regedit). First thing you do is backup your registry in case something goes bad. Then, search for the terms ULPS. Change ENABLEULPS (NOT ENABLEULPS_NA, NOT ANYTHING ELSE) to 0. There are 2 instances of ENABLEULPS to change to 0. They are in 2 different folders. If you're not comfortable with doing this, don't do it.
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-3075835
  • 1 year later...
plz help me!
I appreciate this is a little late, but I have found one piece of info that may shed light on this, which may help other people seeing this issue in the future - Afterburner has an option under the Disable ULPS checkbox, called 'Enable unified GPU Usage monitoring' that's checked by default - if this is on, only GPU1 will ever show usage as this is actually usage across all both GPUs in the r9 295x2, disable the option, click OK and restart Afterburner and you'll see the GPU2 usage.
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-6649115
@Santhox - What fps are you getting when to start up Unigine Valley? If it's around 100fps on the first scene, then both GPUs are working. If it's around 50-60, then only one is working.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-6650445
Good to know. I was wondering why it showed the same usage on both GPUs when I'm only using 1 in games that don't support crossfire. ;)
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
https://linustechtips.com/topic/224531-r9-295x2-problems/#findComment-6650452
