PC will restart randomly
Go to solution Solved by Achois,
So i downloaded CCleaner and i cleaned my part of dust, and made sure everything was connected correctly. i've been running my pc for a few hours now. playing all games. watching videos. seems fine now. thank you. i hope it stays this way.
I've looked around the Forums and saw that some people have the same issue and it is mainly either overheating issue or a PSU problem. My PC will crash after a certain amount of time. whether i am gaming (BF4, WoW, LoL, etc.) or just surfing the web (youtube, netflix, facebook, etc.) I'm new to all this, so I am kinda of confused because i thought i bought a PSU with enough power. Do i need more? this was my first build with a help of a friend, we built it about 2 months ago never had any problems until about 4-5 days ago. Sorry if this is repeat of other posts, but when i looked at the other posts they seemed to have a lower PSU than mine in turn i don't really know how much power i need.
My PC specs.
and tempatures
CPU temp: 24°C -30°C
MB temp: 26°C
VRM temp: 37°C
PCH Core temp: 41°C
https://linustechtips.com/topic/223290-pc-will-restart-randomly/
You should have enough power.
Make sure everything is plugged in and you have all the proper drivers installed
https://linustechtips.com/topic/223290-pc-will-restart-randomly/#findComment-3059102
@Achois Welcome to the forum! :)
The PSU is fine, actually 1000W is more than enough for what you need. (1000W is going to be enough if you decide in the future to add an additional Titan Black)
Maybe your computer is infected with a virus or other malware that automatically shut down your computer. Download MalwareBytes and check if that's the problem or not.
Download CCleaner to clean up your computer a little bit (it will delete unnecessary stuff in your computer like the Temporary Files for example).
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/223290-pc-will-restart-randomly/#findComment-3059121
your PS is fine unless its faulty but usually thats not the problem
and are toughs temps at idle or with load?
I believe they are at idle. not sure how to check that.
i'll try that.
i use AVG idk if thats any better or about the same as MalwareBytes. I will download CCleaner tho.
thank you all for the suggestions. i'll try them and update.
https://linustechtips.com/topic/223290-pc-will-restart-randomly/#findComment-3059191
https://linustechtips.com/topic/223290-pc-will-restart-randomly/#findComment-3065025
