Hi, I was doing my homework on "Comparing Three Numbers". For some reason, it ALWAYS picks number 3 for some reason, for both smallest and largest, and wondering why it did that.
TextWindow.WriteLine("Please enter your first number")num1 = TextWindow.ReadNumber()TextWindow.WriteLine("Please enter your second number")num2 = TextWindow.ReadNumber()TextWindow.WriteLine("Please enter your third number")num3 = TextWindow.ReadNumber()If num1 > num2 And num3 Then  largest = "Number 1"ElseIf num2 > num1 And num3 Then  largest = "Number 2"Else  largest = "Number 3"EndIfIf num1 < num2 And num3 Then  smallest = "Number 1"ElseIf num2 < num1 And num3 Then  smallest = "Number 2"Else  smallest = "Number 3"EndIf TextWindow.WriteLine("The smallest number was: "+smallest)TextWindow.WriteLine("The largest number was: "+largest)
Help is appreciated
https://linustechtips.com/topic/223197-problem-with-a-small-basic-program/
Maybe try adding:
"ElseIf num3 > num1 And num2 Then"
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
i would do something like this
varibles
num1, num2, num3, highest, lowest as integer
num1 = number input
set highest and lowest to num1
(otherwise lowest number will come out as 0 as it will default to 0)
num2 = user input
if num2 is < lowest then
lowest = num2
if num2 is > highest then
highest = num2
num3 = user input
if num3 is < lowest then
lowest = num3
if num3 is > highest then
highest = num3
print out highest and lowest number
You can do this with less code, it's what i would start with.
What language you coding in?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
varibles
num1 = number input
num2 = user input
lowest = num2
highest = num2
num3 = user input
lowest = num3
highest = num3
What language is it?
Small Basic
You cannot say "num1 < num2 and num3" you have to say "num1 < num2 and num1 < num3"
If num1 > num2 And num1 > num3 Then  largest = "Number 1"ElseIf num2 > num1 And num2 > num3 Then  largest = "Number 2"Else  largest = "Number 3"EndIf
I would agree with this. The structure would be:
If (Condition is true) And (Condition is true) Then<Do Something>
I've never used small basic but I can only assume that it doesn't return true if a number is more than 0 when used as a boolean.
I agree with these two :D By saying
it's counting num3 as it's own condition.
  • 2 weeks later...
