Please help me decide
Solved by Mooshi,
they din't carry it
well I thought it might run cooler if it's on water cooling I saved enough to upgrade thinking it may run cooler
If the temps are fine though, you should be good. Unless you're getting some bad overheating.
Kyle89 ·
Posted in Troubleshooting1 -
1
4
ken43 ·
Posted in Troubleshooting5 -
5
thedood2k ·
Posted in Power Supplies3 -
1
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
