I used to have everything wireless. It was just too annoying. I prefer not having to worry about batteries at all.
The only thing better is that when I place my PC in front of my TV every one in a while, I do miss that, because you sure have a lot of cables and have to watch cable length.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
unless your PC is on the other side of the room - wired
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
Other than a htpc or mobile device whats the point of wireless on a device that never get moved?
One word "batteries"
my last keyboard was wireless before i moved to wired and it wasn't bad till the battery got low and you started typing liiiiiiiiiiikeeeeee thhhhhiiisssssssssss.
then you need to replace batteries, i went for rechargeable so was to bad as i always had some ready to go.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Wired, because they dont make wireless MX Blue keyboards :P
Actually they do i had one/have a broken one with browns.
Less wire cluttering ?
For a subpar device with less selection I think not. Also its one wire so that really isnt all that much clutter.
Pretty much ditto @TheProfosist ... but another thing I've found myself liking recently is Wireless/Wired where it's wireless but rechargeable with a cable and not replacing batteries as sometimes Wires get tangled and such or come loose or get cut and can't always be replaced...
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
Assuming the PC won't get moved, wired keyboard and wireless mouse. I change my G602's batteries at least every 2 months and thats with it always on so I don't mind...
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
Wired, but I own an exercise bike with an attached desk for laptops or wireless keyboards. So, sometimes I'll hook the TV up to my computer and game using my wireless mechanical keyboard/mouse because that's about the only time a lazy bastard like me is going to get any exercise. xD
