Triple Monitor Issues - Need help.
Solved by Sebajiya,
Yes. The setup I have is DVI, HDMI and then HDMI with an active Displayport converter. The converter has to be active, can be a little expensive but its the only way it will work.
Welp! spent £20 on two wires already! Oh well if I must spend more then I must.
cannot say I don't have enough wires now
Featured Topics
Denz006 ·
Posted in Troubleshooting2 -
ljukii ·
Tesioniro ·
Posted in New Builds and Planning2 -
18
9
TannerMcCoolman ·
Posted in LTT Releases8 -
1
6
