Hello,  I currently have an amd 6300 currently running at stock speeds.  Will it bottleneck?  Please link me to were you get your information.
Thanks! :D
yes it will i had an FX-8320 running at 4.6ghz and it was bottlenecking my GTX 780 in many games including modern games at 1080P.
If you play at 1440P you'll get 40FPS and NOW the card will no longer be bottlenecked...a 780 push upward of 70FPS in most modern games at 1080P and no AMD CPU ATM can do that.
Also, a GTX 970 should be cheaper and it performs better while consuming less energy so you should look for that instead, do the upgrade and then when you'll realise you're not getting all the performance from your new GPU
do just like me and upgrade ot an intel i5 or i7.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Most likely yes it will.
Also I'd suggest a 970 instead as its newer, faster, costs less, uses less power, produces less heat, makes less noise.
Thanks! :D
yes it would  for a new nvidia gpu I recommend 970
Btw once DX12 is out it shouldn't bottleneck although i would recommend overclocking the hell out of your cpu
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
I was only interested in the GTX 780 because I could get on brand new for $290-$330 depending which one I went for.
go for it then, you'll still see a huge benefit you'll be able to crank up the anti-alisaing and play most games maxed out at 50+ FPS it's worth it
Just don't monitor your GPU load constantly to see if your card is bottlenecked and you'll be fine...always play with 4xMSAA or better!
You play at 1080P right?
what brand gigabyte asus evga zotac
Heres the thing,  my case maxes out at GPU of 10.5 in.  So I would have to order a new case.
yup unless you could cut an opening through the HDD cage or mod your case...the DCII is 11.33 inches long.
ASUS DCII for $290 and the ASUS Poseidon for $330
do you plan to watercool
No, not my GPU. Maybe my CPU in the future.
then why poseidon as that is made as a air water combo its claim to fame is that it has an integrated water block
Well to be honest.  I did not know that.  Thank you!  You might have saved my from spending the extra $$. :D
your welcome
How long do you think the 780 will be in stock at that price?
until they are all sold out...people are buying them for SLI atm so i would say not for long will you still be able to get one new online or in store...but the 970 is better and won't cost much more if anything.
