OBS & rendering hardware?
Solved by SkilledRebuilds,
Nope, the 5450 has a decoding engine, but not an encoding engine for capturing AFAIK.
You could 'maybe' use AMD's Game Capture Raptr with little performance hit on your APU. It can stream and capture, however I do not know if its enabled by default once installed.
I'd look into that if your currently using the CPU to do so.
