Here's my build:
Intel i7 4790k
Shadow Rock Slim ( I don't plan on doing too heavy an overclock)
ASUS Z97 Pro Wifi
2x GTX 980's in SLI
16 gb Corsair Vengeance RAM
120 Samsung Evo SSD
3 Tb Western Digital Red Hard Drive
Define R4
Corsair Builder Series 750 watt psu
ASUS Pb278q 1440p monitor
Windows 8.1
Any bottlenecks/problems/recommendations?
https://linustechtips.com/topic/219523-my-1440p-rig-plan-any-problems/
seems like an alright build to me :)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Here's my build:
Intel i7 4790k
ASUS Z97 Pro Wifi
2x GTX 980's in SLI
120 Samsung Evo SSD
Define R4
Windows 8.1
If ya got the money HELL ya! lol but two 980's is alittle overkill unless you plan on getting a 144hz monitor but I would suggest one 780 ti.. It packs more power and can max any game on 1440p :D
CPU¤Core i5 5675c ¤Cooler¤Ghetto water loop(Cheap tubing & block from amazon)¤GPU1¤Sapphire R9 290x Tri-x¤MOBO¤Asrock H97m Anniversary ¤RAM¤8GB DDR3 1866Mhz¤Storage¤2Tb SSHD & 320Gb HDD¤Case¤Cougar Spike Mini ITX case¤PowerSupply¤500w EVGA 80 plus¤
