Hello,
Do i want static pressure fans for the hyper 212 evo?  i see that it holds 2 fans, so i want 2 fans that are really good for that cooler, that are under 20 dollars total, NOT EACH.
Thanks
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/219331-cpu-cooler/
Yes. Any fan thats right against an obstruction should be static pressure for optimal performance.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006850
Yes and where are you from and which website would you prefer to buy from?
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006855
Static pressure is good, but push/pull isn't necessary. A single Corsair SP120 fan will cost you $20 on Newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181024&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006861
im in the us and i don't care what website, just the lowest price
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006862
http://pcpartpicker.com/mr/newegg/corsair-case-fan-co9050005ww
i wanted 20 for both fans, not one
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006868
Get one Nb eLoop 120mm, it's better than sp and most noctuas
COOLING:
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006872
I found a pack of three of the b12-2 which are the ones i want for my system.  are those going to be quieter than my stock intel lga 1150 cooler?  if one will be quieter, will two be quieter?
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006915
One will be worlds quieter, two might not be. But all you really need is one fan. You'll see a 3-5C drop in temps at the most with another fan. Not to mention it will probably be noticably louder.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006933
Yeah they're gonna be good
COOLING:
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006937
ignore what i said about the three pack, can u link me to a us retailer who will sell me at least one for 20 $ or less
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3006953
I am actually doing this pretty much for sound not temperatures, so will a corsair sp120 or nb eloop 120 be noticably quiety than the fan that comes with the hyper 212
evo
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3007131
evo
NB-eLoop will be noticeably quieter (especially if you're a quiet freak like me).
But again, with two fans it will be louder.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3009022
can u find me a place to buy one in the us for sub 20 $
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3011195
Apparently the eLoops are $25+. but the next best is the BlackSilent Pro. http://www.frozencpu.com/products/12692/fan-826/Noiseblocker_NB-BlackSilentPro_PLPS_120mm_x_25mm_Ultra_Quiet_PWM_Fan_-_600-1500_RPM_-_8-24_dBA.html?tl=c365s936b160&id=GHSv8VhR
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3011307
i'm looking for quiet as possible, will this adequately cool my cpu attatched to the hyper 212 evo
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3013311
It should.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/219331-cpu-cooler/#findComment-3013326
