Hi, ive got someone who wants me to build them an everyday pc (they wont be using it for gaming) and i managed to come up with a few options, anyone know which would be the best, or could help optimize it?  I also want it to last a while (meaning it wont be slow for every day stuff for a while). In addition they would be using it for some sound editing as well.
(in order of cost)
Builds:
1.) super simple amd build http://pcpartpicker.com/user/sailtacks/saved/HNsV3C ($300)
2.) similar above but nicer case and different mobo http://pcpartpicker.com/user/sailtacks/saved/JbyH99 ($338)
3.) sort of an upgrade to the other 2 http://pcpartpicker.com/user/sailtacks/saved/2m26Mp  ($394)
4.) uses an intel instead of amd http://pcpartpicker.com/user/sailtacks/saved/4nXV3C ($552)
This is my first time building at this price point so any help/advice is hugely appriciated.
(also any recommendations are welcome, and please tell me about the speeds they would run at (in your opinion/in as great detail as possible) because thats what really has me nervous)
https://linustechtips.com/topic/219253-need-help-deciding-budget-build/
What is your budget for one?
made a build with a apu and ssd
CPU: AMD A8-5600K 3.6GHz Quad-Core Processor  ($79.99 @ Amazon)
Motherboard: Gigabyte GA-F2A55M-S1 Micro ATX FM2+ Motherboard  ($34.69 @ Newegg)
Memory: Kingston Fury Series 4GB (1 x 4GB) DDR3-1866 Memory  ($42.94 @ SuperBiiz)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Case: Rosewill FBM-02 MicroATX Mini Tower Case  ($22.99 @ Amazon)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Micro Center)
Sound Card: Asus Xonar DGX 24-bit 96 KHz Sound Card  ($27.99 @ NCIX US)
Wireless Network Adapter: Asus PCE-N53 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($28.99 @ Newegg)
Total: $381.55
Generated by PCPartPicker 2014-09-20 21:15 EDT-0400
Total: $381.55
it would be awsome if it could have usb 3.0 headers for the line glow case
would go over budget for usb 3.0
Motherboard: Gigabyte GA-F2A88XM-HD3 Micro ATX FM2+ Motherboard  ($55.18 @ Newegg)
Total: $417.04
Generated by PCPartPicker 2014-09-21 00:03 EDT-0400
Total: $417.04
couldnt i just pass on the ssd?
also : https://pcpartpicker.com/part/rosewill-power-supply-arcm450
is that a good deal? it seems to be so im thinking i should get it tomorrow
in your original post you said "meaning it won't be slow for everyday stuff for a while", since you said you don't want it to be slow, i'd added a ssd to increase loading times for programs and other things, although you could just ditch the ssd and save up for one later in the future
i agree with what you're saying, yeah i understand why you would include it (its not too over budget so ill see)  out of curiosity, how well did i do in finding the parts that i first listed?
if you went with the 3rd build, you would have not video because there's no igpu in that cpu, you would have to get a discrete graphics card
out of those build that you made, i would choose the intel one
out of curiosity, i have to build a gaming computer that could eventually get a psu upgrade second gpu and have a water cooling loop (as well as look cool) what i have is really near for their current budget (the upgrade comes later) but what do you think? : http://pcpartpicker.com/user/sailtacks/saved/LWBzK8
cheaper
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.73 @ OutletPC)
CPU Cooler: Swiftech H220-X 55.0 CFM Liquid CPU Cooler  ($137.75 @ NCIX US)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Micro Center)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 980 4GB Video Card  ($549.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($34.99 @ Micro Center)
Case Fan: Phanteks PH-F140SP_BK_BLED 82.1 CFM 140mm  Fan  ($12.99 @ Newegg)
Total: $1449.36
Generated by PCPartPicker 2014-09-21 00:36 EDT-0400
cheaper
Total: $1449.36
pc part picker says that motherboard doesnt support sli, making it not possible to add a second in the future to run sli
