I won't be watercooling for awhile and my cousin could use my 212 evo in his build, so I've been thinking about getting a better cooler for temporary use.  It'll probably get re-sold when I do my custom loop. I want the cooler to be better than my 212 evo pls
I don't have very much room around the CPU socket and I'd like to keep my SP120 QE's in push pull on whatever cooler I get, what options do I have? I'd like black if possible.
Right now the 212 evo isn't tall enough for the fans to clear the ram, so if I do get something bigger it'll have to be taller so that it fits over the dominator platinums, (which I don't think any air coolers do but i'm not sure)
Here's how much space I have, also the case is an R4
Would an AIO be better?
https://linustechtips.com/topic/219084-quick-question/
Hi Darren
https://linustechtips.com/topic/219084-quick-question/#findComment-3003763
Can't you just move the fan up?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/219084-quick-question/#findComment-3003765
Why not revert to the stock cooler until you get your custom loop?
https://linustechtips.com/topic/219084-quick-question/#findComment-3003790
it fits on the 212 right now, but what I meant is if the 212 was "thicker" then the fan would hit the ram, then if I moved the fan "up" it would have like 1/4 of the fan not pushing air through the fins
https://linustechtips.com/topic/219084-quick-question/#findComment-3003800
I want better cooling performance until I get the custom loop, I like running my fans at 5v and the 212 evo struggles sometimes when I start overclocking
What do you consider 'cheap'?
I can spend up to ~100$
https://linustechtips.com/topic/219084-quick-question/#findComment-3003829
tNoctua claims that the U12S/U14S has 100% memory compatibility.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/219084-quick-question/#findComment-3003846
The U12S claims (PCPER)
will that outperform my 212 evo?
https://linustechtips.com/topic/219084-quick-question/#findComment-3003859
Yes, and also I checked and the U14S has the same cost as the U12S while also maintaining the memory clearance.
I updated my original post with links.
https://linustechtips.com/topic/219084-quick-question/#findComment-3003884
The sp120's wouldn't fit on the u14s though.
Easily.
https://linustechtips.com/topic/219084-quick-question/#findComment-3003915
Have you considered the NHC14?
http://pcpartpicker.com/part/noctua-cpu-cooler-nhc14
Or you could go with something like an H80I/H100I
https://linustechtips.com/topic/219084-quick-question/#findComment-3003946
Easily.
From benchmarks it seems not by much, only like 4 degrees
Should I look into an AIO?
https://linustechtips.com/topic/219084-quick-question/#findComment-3003949
What kind of reviews are you looking at?  :huh:  http://www.techpowerup.com/reviews/Noctua/NH-U12S/6.html
If you're going for quiet, I'd suggest sticking with air.
https://linustechtips.com/topic/219084-quick-question/#findComment-3003978
This is what I was looking at, I only looked at one review on google I didn't explore much afterwards:
http://www.anandtech.com/bench/CPUCooling/772
I had an h100i like.. 8 months or so ago and I don't remember it being audible in terms of pump noise, I'll look and see if amazon has the u12s. (Have amazon prime for a month so I figure I should use it)
I can use my SP120's on it right?
https://linustechtips.com/topic/219084-quick-question/#findComment-3004038
Yes, you can use SP120's on it.
https://linustechtips.com/topic/219084-quick-question/#findComment-3004182
Is there anything bigger & better? I'm willing to spend the $, just figured I'd ask, I'm not entirely sure how long I'll be using it but it may be for a few months.
I know my 4790k can do 5ghz, and I'm not entirely sure if I'll be able to hit 5 with a smaller cooler. ( Already booted at 5ghz with my 212 evo, but temps were wayyy to high for that)
Is there anything similar to the NH-D15 that has support for 120mm fans with memory clearance?
I'd buy an NH-D15 but I want to continue using my fans since they match everything
https://linustechtips.com/topic/219084-quick-question/#findComment-3004271
The u12s is a smaller cooler but has a denser fin array than the 212 Evo. What were your load temps with the 212 Evo?
https://linustechtips.com/topic/219084-quick-question/#findComment-3004453
When gaming ~60c at 4.4 ghz 1.18volts with the fans at 5 volts, when I was benching 4.8 ghz @ 1.325v it was hitting 80c with the fans at 12v
I just want something beefy enough to withstand a stability test/benchmark without hitting 80+ @ 1.4v
https://linustechtips.com/topic/219084-quick-question/#findComment-3004557
I just want something beefy enough to withstand a stability test without hitting 80 @ 1.4v
You'd probably need to go liquid if you want to hit 5ghz and stay under 80c while using the SP120's.
That or you'd need to delid.
https://linustechtips.com/topic/219084-quick-question/#findComment-3004587
It was only hitting like 86c with the 212 evo, so I think the u12s would hit about ~78 maybe
https://linustechtips.com/topic/219084-quick-question/#findComment-3004610
That could work if you don't mind having the fans run at 12v.
https://linustechtips.com/topic/219084-quick-question/#findComment-3004689
Can't you just get a U14s and use stock fans until you get your loop going, I know you're not a fan of noctua fans but it'll only be temporary right?
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/219084-quick-question/#findComment-3004786
If I was going to do that I might as well get NH-D15 right?
https://linustechtips.com/topic/219084-quick-question/#findComment-3004821
