hey im almost done with my first build, but i need a cheaper mobo, could someone please recemend a good but cheaper mobo? https://pcpartpicker.com/user/sambo656/saved/ thanks in advance!
https://pcpartpicker.com/part/gigabyte-motherboard-gah97gaming3
i would highly suggest an unlocked CPU
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/218602-help-almost-done/#findComment-2997953
for 3 more dollars, you can get a unlocked cpu
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Micro Center)
Memory: Corsair XMS 8GB (1 x 8GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Video Card: PowerColor Radeon R9 280 3GB TurboDuo Video Card  ($181.10 @ Newegg)
Case: BitFenix Comrade ATX Mid Tower Case  ($39.99 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Monitor: BenQ GW2255 60Hz 21.5" Monitor  ($109.99 @ NCIX US)
Total: $921.08
Generated by PCPartPicker 2014-09-20 00:32 EDT-0400
https://linustechtips.com/topic/218602-help-almost-done/#findComment-2997997
do you really think im going to be overclocking?
So you are certain that you wont ever oc?
https://linustechtips.com/topic/218602-help-almost-done/#findComment-2997998
Total: $921.08
hey dude ive looked for a bit and i cant really find a comparison between the powercolor r9 280 and the gigabyte r9 280 is there much of a difference?
https://linustechtips.com/topic/218602-help-almost-done/#findComment-2998099
i just choose the powercolor one because it was cheaper, not much difference
http://www.techpowerup.com/gpudb/2405/radeon-r9-280.html
https://linustechtips.com/topic/218602-help-almost-done/#findComment-2998108
