Hey tehies!
I'm planning out my runs on a NZXT Phantom 820, and could really do with some help.
My predicimnet:
My res will be in an optical bay
Not sure where my pump should go
my triple rad will cause problems with run length
Here are 2 ideas that I have. I cold really do with some help with this, feel free to edit the empty image below!
Production Control, Fish Keeper, Lover of Audio
https://linustechtips.com/topic/21848-help-me-with-some-runs/
Both options look fine. Whatever you can do to have shorter runs is best so having the pump by the res would be a better option out of the two.
Just make sure you put something under the pump to cut down on vibration.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-270494
The bottom one has a long from from the drive bay to the pump, It will look better without it.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271043
Get a pump res combo to save on space and make the system look neater.
Do you recomend this? Cos my system is already extreemly expensive, and I'm going full XSPC cooling, my only choices are:
http://www.overclockers.co.uk/productlist.php?groupid=962&catid=2133&sortby=nameAsc&subid=1845&mfrid=427
My current choice adds up to: £91.96
XSPC D5 Vario with Front Cover (1/2” barbs)
XSPC Single 5.25” Bay Reservoir - Multi Fascia
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271135
Get the second one from that list.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271164
That adds over £100 to my budget! Damn :(
Trying my best to keep it under £3000
Oh wait, that res is made for two D5s; that's why.
Look at this one: http://www.specialtech.co.uk/spshop/customer/XSPC-Acrylic-Dual-525-Reservoir-for-Laing-D5-pid-11671.html
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271231
You are my new hero!
Its even less than the pump and res individually!
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271247
That is the res only. You still need to buy the pump for it.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271258
Damn, that pic decieved me XD
I've got it with a pump now, for ~ £85
That's still a good price.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-271459
  • Hose cutter is a waste of money, just use a scalpel.
I don't see your GPU blocks for that SLI fitting but I assume they are XSPC so they will fit.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-272244
  • I don't see your GPU blocks for that SLI fitting but I assume they are XSPC so they will fit.
I'll get rid of the hose cutter
I'm running 2 GTX 770's, so the blocks don't exist yet
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-272326
with the 360 rad have u looked at the xspc crossflow rad so it will help with the runs
http://shop.xs-pc.com/xsp/XSPC-EX360-Crossflow-Triple-Fan-Radiator_29046.html
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-272970
If you know much about this, is it as good as an RS series, cos I really wanted to get it....
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-273071
Cross-flow rads have worse performance if I remember correctly.
https://linustechtips.com/topic/21848-help-me-with-some-runs/#findComment-273073
