Would Audioengine A2+ work with my subwoofer?
Solved by Aniallation,
i will buy Audioengine A2+ but since i already have a subwoofer that came with Z523 ..can i plug A2+ with it ? using Aux input ?
if not is there any possibility to make A2+ work with Logitech Z523 subwoofer ?
There is a way but it will require modding. Using them at the same time out of the box will force you to use one of the Z523 speakers in order to power on the subwoofer and control volume.
If you want to use the A2+'s with only the subwoofer of the Z523, you'll need to take apart the speaker with volume control and disconnect the speaker(s) inside.
