Hi all,
I'm running in to some problems getting 3+1 surround to work on the new WHQL drivers from nvidia (344.11)
When i install em all goes well and all monitors work fine when i activate all displays in de cpui....
SLI i can enable aswell but the moment that i wanna enable my 4th screen it turns off , i cant enable it in the monitor config (i can click the extra but it wont enable)
The screen goes black and even the port on my vidcard apparently gets disabled.. ( oO )
Now i've been at it for quite some time now (watching #mod24 on my laptop) but i cant find a solution..
I tried moving the connectors around un/reinstalling using DDU and such but no go
According to the release notes 690's are supported..
Strange thing also is that when i do the sli setup it switches the outputs around aswell (screens get diffrent numbers every time i use the setup, wich..., well gets me baffeled..., serious WTF moments)
I'm using win 8.1 x64
--- CoolerMaster Cosmos II, Asus RoG Rampage IV Black ED, 3 way SLI GTX980's, Intel i74960x @4500Mhz, 16Gb Dominator Platinum 2666Mhz, 3x 25" +1 27"  Surround (6040x1080p +1920x1080), Asus RoG Xonar Phoebus 7.1 15Tb WD HDD's, 1 Samsung 256Gb 830 SSD (gaming disk), 2 Intel 730 256Gb SSD's (Raid0)  --
https://linustechtips.com/topic/218278-34411-drivers-4th-screen-problems/
would be strange that these drivers demand something like that all of a sudden i've been running this setup for quite some tme now without any problems..
i'm searching around and allthough peepz do have sporadic problems with surround with these drivers none so strange as mine :P
only thing i can think of atm is that these drivers dont like quadsli... bcause running the 340.72 set i have no problems..
