Is my build going be fine, and what power supply and monitor should I use, but I don't want to spend a lot.
Motherboard- Asus A88XM-A AMD Socket FM2+ SATA III USB 3 PCI-E Micro mATX Motherboard
Cpu-AMD A8 5600K Black Edition 3.6GHz Socket FM2 4MB L2 Cache Retail Boxed Processor
Ram- 8gb ocz pc3 10666 DDR3 pc ram 4 x 2gb gold series
Case- ZALMAN CASE MIDI Z9 PLUS BLACK
https://linustechtips.com/topic/217591-my-build/
well, it depends on if u plan to include a graphics card, and what card that would be.  if no gpu, then grab the corsair cs430 and for a monitor, i love my asus vx248h, but it may be a bit premium for what you want.  grab a standard 1600x900 or 1920x1080 monitor for as cheap as you can on pcpartpicker.  some good brands are aoc, benq, acer, asus, dell, samsung.
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/217591-my-build/#findComment-2983987
May be you can tell me what gpu is good and cheap for the build
https://linustechtips.com/topic/217591-my-build/#findComment-2984195
Thank you so much for actually linking a build.  I have a a 600 dollar budget, less is great, but i can afford a better gpu and i want at least a 120gb ssd.  Thank you so much
https://linustechtips.com/topic/217591-my-build/#findComment-2988892
For a 600 dollars budget i'd go with something like this: http://pcpartpicker.com/p/Nj3kqs.
If its only for gaming i might went with pentium and a better graphics but you said some server running and stuff so i3 might do a better job.
And if you dont go for 260x or more strong GPU i dont think you will need more than 1GB of Vram.
https://linustechtips.com/topic/217591-my-build/#findComment-3003258
