Budget: 220$
Build:
Intel i7-4790k Corsair Cooling Hydro Series H100i ASUS MAXIMUS VII Formula Corsair Vengeance Pro rot DIMM Kit 16GB PC3-17066U Samsung Serie 840 EVO 250Gb 2,5" 6GB/s Western Digital WD Black 2TB, SATA 6Gb/s EVGA SuperNova 750
BenQ XL2420Z
Prolimatech PK-1/Thermal Compound
Preferations for the Case:
-> Good Airflow
-> Full dust Proof/Amlost fully dust proof
Hope you guys can help me out.
https://linustechtips.com/topic/217509-need-help-with-choosing-case/
Budget: 220$
Build:
BenQ XL2420Z
-> Good Airflow
i think this will be a nice option :)
Budget: 220$
Build:
BenQ XL2420Z
-> Good Airflow
Do you mean $220 USD?
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Budget: 220$
Build:
BenQ XL2420Z
-> Good Airflow
Thermaltake Chaser Series Chaser MK-I
This is the case I'm currently using, i LOVE it!
full steel constuction, and has mounts for 4 200mm fans.
i was able to lower the load temps of my GPU by 10 degrees, which i then brought up by overclocking :)
FULLY DUST COVERED!
any questions let me know. (the price is around $150)
Cases really come down to personal preferences, I personally love the Fractal Arc series. Good airflow: check. Dust covers: check. Simple and elegant swedish design: check. I have the mATX version and I've been loving it.
Yes I do
Okay. Tis always helpful to include your currency or provide your country info in your profile settings under 'Location'. ;)
