Upgrading from 2600k, need advice
Solved by Maverik5124,
So more or less what I'm getting is don't buy Haswell until we see real benches and if I can get the same or higher OC. For what I need (Higher threaded performance), go 2011 which was obvious over what AMD has to offer. I don't plan to change out my GPU's anytime soon since they blow everything I have out of the water with ease, they are 680 Lightnings of course. I wouldn't mind going Water cooling, but my case and the fans I am using keep the computer even under real heavy load very cool. So I think I am better off atm saving up for a 2011 board and possibly for a Ivy-E CPU when they do come out.
Exactly :D
