Hi, I am trying to decide a monitor for PS4
jchang
Hi,
I am trying to get a monitor for PS4.
One is ASUS VX228H Black 21.5" 1ms GTG
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236358
And another one is Acer H6 Series H226HQLbid Black 21.5" 5ms GTG
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009484&cm_re=H226HQLbid-_-24-009-484-_-Product
ASUS has faster responsive time and non glare screen.
ACER has slower responsive time but has better screen quality, yes it has glare.
I am leaning towards Acer monitor but,
If you were to choose a monitor for PS4 gaming,
what monitor would you choose??
P.S: This monitor will be used for my PS4 Laptop Project I am working on... ^^
Acer
Choose the Acer, the panel itself will look much better.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
The acer monitor, anything under 7ms latency isnt noticeable as humans have an average reaction speed of 7ms, thats recorded via the Olympic official rules.
Unless you want placebo effects everywhere, quality wins here.
Listen if you care.
I recommend the Acer, it may have a slower response time but I think the quality and glare of the screen is more important, especially for your PS4 I recommend the Acer.
RIG:  CPU: Intel Core i5-4690K CPU Cooler: Corsair H80i Motherboard: ASRock Fatal1ty Z97 Killer ATX Memory: G.Skill Ripjaws Series 8GB Storage: Seagate Barracuda 1TB Internal HDD SSD: Samsung 840 Series 120GB 2.5" SSD Video Card: Zotac GeForce GTX 970 4GB Video Card Case: Corsair 780T PSU: NZXT HALE82 850W 80+ Bronze Monitor: LG 34UM95-P Keyboard: Steelseries Apex Keyboard Mouse: Razer Taipan Mouse Mat: Razer Vespula Sound: Cyber Acoustics CA-3090, Corsair Vengeance 2100 :  1998.40 Euro
Don't need speakers?
I wont need speakers because generally, speakers in monitor is worthless,
and I will have speaker system. Thus, don't need monitor speaker.
Ah, just making sure you're covered there haha.
From those two listed, I'd honestly go with ASUS since Acer's build quality is pretty crappy. You should also note that the Acer monitor has an external power brick, so you'll need to fit that into your laptop chassis as well.
Both ASUS and ACER monitor has external power brick.
External power brick is must for me because when building PS4 laptop, having smaller power supply is always better.
If it wasnt external power brick, size of the power supply unit inside the monitor will be outrageous... hahaha
Definitely the Acer, just becuase it's IPS, and the 5ms won't be noticeable.
That would mean the reaction would be a minimum of 14ms (7ms of the monitor, plus average 7ms reaction speed)...
well crap
Listen if you care.
I am looking at the ASUS and Newegg's pictures don't show a power brick...but a reviewer does say it, weird. But this isn't the first time Newegg's pictures have been misleading!
Off-topic: I have a Dell u2312hm and it looks as thin as the ASUS and Acer and my monitor has an internal power brick!
Either way, best of luck to you and I hope to see this somewhere here on LinusTechTips! Maybe in the buildlogs?
Yup, When I am done with the project, it sure will go to BuildLog... ^^
