Hey guys.
My first build is almost complete and as my motherboard doesn't have an on-board wi-fi solution I'm wondering what the best option for me is.
I will not be able to connect via a wire, it has to be wireless.
Our internet is fairly good (45-50 Mbps) and I work from home (in the UK) and play EVE Online so a reliable, strong connection is important.
I have a PCI-E slot (x4) free and could obviously use a usb solution.
What do you guys recommend I use ?
Thank you
https://linustechtips.com/topic/215876-wireless-network-card/
Before going wireless, consider something like Powerline, if possible.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=powerline
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/215876-wireless-network-card/#findComment-2957053
TP-Link WN781ND is what I use. It's PCIe x1
It's a shared house so I'm going to stick with wireless, how much better will the wireless card be if I spend about £25-£30 ?
...and will I be using the PCI-E (x4) slot or another ? Sorry for the noob questions
https://linustechtips.com/topic/215876-wireless-network-card/#findComment-2957139
The PCIe x4 slot will work.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/215876-wireless-network-card/#findComment-2957147
I have a TP-Link USB wifi reciever. I use it 24/7 on my desktop (router is in another room so wireless is the only way) and bring it to school for my laptop which has the worst internal WiFi card ever,  on top of some rooms not getting WiFi at all. Here it is.
Worked on my disk drive-less laptop (somehow) but didn't on my desktop (had to use the disk it came with to install the software).
I honestly recommend USB ones rather than PCI because of portablility. http://www.amazon.com/TP-LINK-TL-WN823N-Mini-Sized-One-Button-10-4-10-8/dp/B0088TKTY2/ref=sr_1_4?ie=UTF8&qid=1410838996&sr=8-4&keywords=tp+link+usb+wifi
https://linustechtips.com/topic/215876-wireless-network-card/#findComment-2962993
