ok so for the third time i try this
i need a new psu
preferably 80+gold
not bothered about moduar or non,
id like nice sleeving.
has to power a 2600k-4.9GHZ /580-1000mhz+/ssd/hdd/5fans.
has to withstand folding abuse.
single 12v rail.
will be using, Scan,ebay,sbuyer,aria,amazon to buy from and need one ASAP.
cheers guys!
https://linustechtips.com/topic/21454-need-a-psu-asap-please-help/
Does the store matter? Also do you have any plans on doing SLI?
store? as in where i buy it? ideally the ones above as they are easy to use.
and no, no sli planned but am considering GTX780.
Woops. Misread what you typed in your OP. Alright, I'll be looking there. You'll need probably 650-750 watts. Right now, I'm trying to calculate your power usage using a calculator(with the information provided) to be as accurate as possible.
Based on the provided information, PSU calculator(Extreme power supply calculator) says you'll need a recommended wattage of 540 watts. So 650 watt PSU for future upgrades. Even with a Titan(for reference here), you'll still only need a recommended wattage of 545 watts.
A cx600 will be plenty. No need to waste money now...
http://www.amazon.com/dp/B0092ML0OC/?tag=pcpapi-20
A 780 will also be fine on a cx600.
Since you're not gonna go SLI, go with a 600W PSU. Seasonic and Corsair are the brands I would recommend. Something like a HX650 would be perfect and it's 90 quid on Amazon
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
Okay.
With that kind of a budget, I really would not recommend the CX-series. It's typically overpriced for what it's worth, overall quality isn't particularly great either.
I'd recommend either the XFX ProSeries 650w or the Fractal Design Newton 600w. Both are very good units for the respective price points, the Newton especially is comparable to higher-end units in terms of quality and performance.
Super Flower Golden Green (Gold) and King(Plainum). 550W is enough.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
The Seasonic X650 and the Corsair HX650 psu will be enough to handle your GTX 780.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
