My PC specs are:
AMD FX 9370
Sapphire Radeon R9 270x
Corsair H60 liquid cooler
GA fxa990 ud3
8gb of G.skill Ripjaws 1866 RAM.
When I turn on my system the fans spin up, and after a few seconds the entire thing shuts off. I turn it back on and the same thing happens. Any advice would be appreciated.
https://linustechtips.com/topic/213668-help/
Over heating maybe
Edit: And why would you post in this section....
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/213668-help/#findComment-2920270
This is probably the wrong forum, but.. it sounds like something might not be plugged in properly. Also, are all the mobo standoffs installed?
I7-4770k 4.7Ghz 1.35v | Asus Maximus VI Extreme | 16GB Dominator Platinum 1866Mhz | 2x GTX Titan SLI
Custom Water Loop | Corsair AXi 1200w | Intel 530 series 240GB SSD | 1TB WD Black
Corsair Obsidian 900D | Sennheiser 558 | Ducky Shine Zero Cherry MX Brown w/ Orange Backlight | Func MS-3 | Dell U2141H x3
https://linustechtips.com/topic/213668-help/#findComment-2920276
My PC specs are:
AMD FX 9370
GA fxa990 ud3
PSU?
Bad board?
Bad CPU?
I'm suspecting the PSU or the Mobo here.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/213668-help/#findComment-2920303
You can also try taking out the video card and then turning it on.. but yea..too little information to diagnose anything.
https://linustechtips.com/topic/213668-help/#findComment-2920343
Thought this might be helpful for you.
https://linustechtips.com/topic/213668-help/#findComment-2920442
Gotta love those "HELP AHHHHHHHHH!!!!!!!@#$@^@#^" titled threads lol.
Particularly when they're posted in the "hot deals" section.
Only thing hot about this is OP's CPU temperatures (possibly) - huehuehuehuehuehue.
But nah it's probably a PSU/shortcircuit issue or a loose cable.
https://linustechtips.com/topic/213668-help/#findComment-2920614
I thought the same thing, but there's something funky with the link. If you look at the top of the page, the path to this link is
  1. Linus Tech Tips
  2. Community Portal
  3. Troubleshooting
Strange, because I also got here thought the "hot deals" page.
i7 4770k @ 4.6ghz | Gigabyte GA-Z87X-UD3H | G.SKILL Ripjaws X Series 16GB | Sapphire Vapor-X 7970 Ghz | Fractal Design Arc Midi R2
Samsung 840 EVO 250GB SSD | Toshiba 7200rpm 3TB | Seasonic 660W Platinum | Corsair H100i
Logitech G400s | Ducky Shine III Cherry MX Brown
https://linustechtips.com/topic/213668-help/#findComment-2921599
