3-way SLI
Go to solution Solved by Archangel1994,
Get the EVGA SC version. They have the ref coolers which are excellent for SLI.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904472
Well, it would be best to go with blower style cards. Open designed cards will just circulate hot air around the case. 760T is a good case for it.
Watercooling would definitely help keep temps down, but not necessary.
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904530
diminishing returns from the 3rd GPU is insane..MANY games won't use a 3rd card at all in fact most of them won't so your 3rd card will be sitting there doing nothing MOST of the time...get 2 more powerful card instead, you should look for two R9 290 instead...also you get more memory and faster memory on those.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904586
get two higher-end cards instead
I said I might!
And I'm running FSX on that PC which prefers NVIDIA, so AMD cards are not an option.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904630
Water Cooling is not necessary, but neither is 3 way SLI, you will be better off getting 2 more powerful cards as the performance you get from 3/4 way sli is definitely not worth the money.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904661
Hi
I might do a build with 3 GTX 770s in SLI, but I'm not sure how to cool these cards. Is watercooling necessary? What would be the best case for it (I'm thinking of the 760T)? Thanks.
Meh I would just get dual 780s or something
If you ever want to play  a game that does not support SLI you only have a single 770
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904707
You mean this one? http://www.evga.com/Products/Product.aspx?pn=02G-P4-2771-KR
I'd prefer something with 4GB VRAM, I might switch to 1440p.
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904713
I said I might!
then go with two GTX780, it's much better.
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904828
Don't get the 4GB version of the GTX 770, the card is not good enough to use it all. Get R9 290 Crossfire instead.
https://linustechtips.com/topic/213243-3-way-sli/#findComment-2904837
