Python help!
Go to solution Solved by Enderman,
thank you without you i couldn't get this done! :D you have made my day!
You're welcome! :)
okay guys so im learning python via codecadamy, i know it isnt brilliant and i know it isnt 3.3 but i need help with this piece of code it doesnt work on im stuck
print 'Welcome to the Pig Latin Translator!'original = raw_input("Enter a word!")if len(original) > 0:    print "Please enter a word!"elif len(original) < 1:    print original
it doesnt seem to work, when i run it i get this
Welcome to the Pig Latin Translator!Enter a word! James Please enter a word!None
and i need help please!
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/212293-python-help/
print 'Welcome to the Pig Latin Translator!'original = raw_input("Enter a word!")if len(original) < 0:    print "Please enter a word!"elif len(original) > 1:    print original
You need to reverse your > and  < symbols
https://linustechtips.com/topic/212293-python-help/#findComment-2882497
Not, sure what's wrong...
Try doing this instead:
len(str(original))
nope i tried it i get Oops, try again. Did you remember to use if and else in your code?
print 'Welcome to the Pig Latin Translator!'original = raw_input("Enter a word!")if len(original) > 0:    print "Please enter a word!"elif int(len(original)) < 1:    print original
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882503
I found the problem and edited my first post :)
https://linustechtips.com/topic/212293-python-help/#findComment-2882515
tried your edit it says i have to use else and if :(
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882520
change the elif to else
you can do
else:        print original
instead of
https://linustechtips.com/topic/212293-python-help/#findComment-2882526
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882538
you can do
instead of
thankyou thankyou thankyou, it worked? may i ask why it is differnt block of code depending if its else of elif
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882566
The way you used elif in your first code would have worked too, I guess they're trying to teach you how to do it using else.
elif will basically do another "if" statement if the "if" statement before it failed
else just runs if all if/elif statements before it fail, and its easier because you dont have to type any conditions for it, aka you can skip the "original > 1" part
example:
x=5 if x==1:    print "x is 1"elif x==2:    print "x is 2"else:    print "x is neither 1 or 2"
https://linustechtips.com/topic/212293-python-help/#findComment-2882590
example:
okay thanks im sorry to bug you but there is one more problem
#this checks that it has more that 0 charractars and is just letters and no numbers
if len(original) < 0 and original.isalpha():
else:
        print original im trying to use original.isalpha() but i cnat work out were pot put it
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882630
else:
try:
original = raw_input("Enter a word!") if original.isalpha():    print "Please enter a word!" else:    print original
https://linustechtips.com/topic/212293-python-help/#findComment-2882671
try:
nope that doesnt work it justs prints what you type in
print 'Welcome to the Pig Latin Translator!' original = raw_input("Enter a word!") #this checks that it has more that 0 charractars and is just letters and no numbersif original.isalpha():    print "Please enter a word!" else:    print original
and this is what i get Welcome to the Pig Latin Translator!
Enter a word! 123
123
None
and my error msg is Oops, try again. It looks like your code prints original ("123") when original includes non-alphabetical characters.
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882727
Oh I messed. up, oops.
Switch around the " print original " and " print "Please enter a word!" " lines.
https://linustechtips.com/topic/212293-python-help/#findComment-2882741
}else{
https://linustechtips.com/topic/212293-python-help/#findComment-2882749
You're welcome! :)
https://linustechtips.com/topic/212293-python-help/#findComment-2882759
