mehhh....
Still ike my 450D
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2875990
No 240mm support at the top? Insta-NOPE.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876009
The rads are designed to go at the front. So it does support 240/280 in the front
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876017
As in almost every other case front + another 240/280 at the top..
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876044
I'm just saying, at least it supports rads.
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876053
even a bit fenix prodigy has room for like 600mm of room for rads or fans , really? come on..
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876057
It is $69 USD, it's suprising that it has ample WC support in the first place. And if you are doing an extensive loop, it's likely that you will have more than $69 to spend on a case.
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876092
It is?! O.o I thought it was over $100...
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876126
No.
Possibly in your region, but not here.
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876135
I wish there was a bit more on the front...the front panel just needs....something
Also, I really wish NZXT would stop putting the SSD mounts up front. I hate that I have the whole ssd mounting system right up front-front and center.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876149
Pls,stop rotating your avatars ;-;
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876155
I preordered it.
Its getting a custom paint job..So it will look plain from well the 20min drive from my house to the hands of the airbrush artist.
I was thinking of a simple loop with 280 rad in front but might just get AIO. Until its in my hand, I will know if I can get a Pump/Tube Reservour to fit in it Without being to cramped.
@syrazpc - for all my rambles about PC's -- My Gallifreyan Build In Progress
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876234
Hahahahaha
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2876822
Meh. I'm looking forward to some Phanteks Enthoo mini xl builds (whenever the fuck that thing comes out). I really like dual rear exhaust fans on a system.
Dubs are better than subs
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2877079
OP... I love you, thanks!
It is $69.99... and it's also smaller than most mid-towers, there's a lot in consideration with this case.  :D
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
https://linustechtips.com/topic/211893-first-nzxt-s340-build/#findComment-2877674
