A can of compressed air through the vent hole may get rid of some dust.
Otherwise (if you know what you're doing) open it up and spray out the dust, and re-apply thermal paste.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874851
1. I haven't had a cat, or lived in a house with one while using this laptop
and 2. what bugs? and where are they? is that why it smells burnt from thehole where the air comes out (the name eludes me at this moment)
I think you're looking for "vent".
And I was saying cat hair in a generic term, I'll apologize as my OP was a bit sarcastic. But yes Laptops get full of hair (carpet, natural hair from peoples head etc) and dust. Then there's the occasional bug (I service laptops).
It'd probably be worth opening it up, if it's nice the CPU is easy to get at. There is usually a carpet of dust and crap on the heatsink.
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874886
I don't think spraying the dust in to the machine will solve the problem...
do I really need to re-apply themal paste to the cpu and gpu? dosen't that stuff last for more than 2. years? :S
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874888
Any tools I need? what kind of screwdriver etc? can't really see any screws from the back :S
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874929
Oh yes it will. This is how laptops work.Thy have to be opened and cleaned at least every 6 months or the vents will be blocked of dust and other elements.
You should definitely open it and clean the dust off or send it to a store if you don't want to take any risks.
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874942
Get a cooling pad.  Twas what I did.  You can find some nice ones from cooler master for like 20 bucks.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874946
Spraying it the other way may loosen up the dust that is caught, making it spit out the vent hole when it turns on.
The standard paste that they use is probably crap so applying good thermal paste will improve temps a bit.
Or you can get one laptop fan cooling things. But that makes it harder to sit it on your lap.
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874951
Could I have a picture? And generally a phillips, reasonably small one. Some PITA laptops use Hexscrews etc.
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874952
I can post one a bit later, but that lack of visible screws makes me think that the rubber feet has to go (I hate it when I'm right about these things -.-)
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2874989
Could be. If you're delicate (flathead/razor) they're usually not an issue and stick right back on.
https://linustechtips.com/topic/211798-laptop-running-hot/#findComment-2875216
