Hello guys!I have a problem with the desktop then,i bought some month ago a gtx 750 1 gb version,i connect the vga with my desktop (1280x1024) means the vga cable,and there are no ptoblem the desktop is perfect,but when i connect the pc with a 22'' tv full hd means the vga cable i have a black bar on the left and the desktop moved after this black bar,but on the monitor 1280x1024 there are no  problem why?
I tried to set 1920x1080 on the screen resolution by windows but the problem is the same.
Help me...
https://linustechtips.com/topic/211617-problem-with-the-desktop/
Sometimes with VGA the TV limits to 1600x1200 and sometimes a TV cannot go 1080p via VGA (DVI or newer is required). Check the different cable types.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2872388
Try to use HDMI or DVI
there are DVI to hdmi converters available
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2872394
Thanks guys for the answers!I use the dvi-vga adapter and the vga cable for the monitor,is the adapter the problem?
I just now tried with the minihdmi-hdmi cable,and the desktop is more larger infact the start bar is not seen.I tried to change the desktop by nvidia panel but nothing happens.
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2872450
What TV? Some TVs have limitations.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2872501
I suspect it is a limitation of the TV. Try a monitor if you can.
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2879767
This is the problem,i have only 1 monitor (1280x1024)  :(
To be more blunt, the problem is with the TV. It most likely does not support what you want. I had this issue with an old Samsung TV long time ago. Best bet is to buy a new TV or monitor.
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2880227
You need to check whether the TV supports 1080p, then try using a hdmi cable to connect it to the 750 (assuming the model you have has a hdmi port). Alternatively you can hook up your tv to the graphics card and 1024 to the motherboard if you have integrated graphics.
I have almost the same, 1080p (hdmi) tv/monitor and a 1024 square thing (vga) both running off a gtx 780.
Intel Core i5 3570K @ 4.5GHz | ASUS P8Z77-V LX2 | 2x4GB kingston hyper-x genesis @1600MHz | Gigabyte windforce GTX 780 3xOC rev.2 | 240GB kingston v300 & 500GB seagate 7200rpm |
Corsair GS600 |  1440p Dell U2515H & 1080p 60Hz tv/monitor | Asetek based AIO 120mm liquid cpu cooler
https://linustechtips.com/topic/211617-problem-with-the-desktop/#findComment-2940729
