Motherboards manufacturers usually use CR2032 batteries on most motherboards. You can find these at most hardware or electronic stores and are usually cheap. Just make sure you buy a quality brand so that it doesn't leak or lose power very quickly. Also, most of the time the battery on motherboards lasts 10+ years so be sure to check the "Clear CMOS" jumper if you're having concerns for why you're loosing your CMOS data, if that's the case.
https://linustechtips.com/topic/211446-motherboard-battery/#findComment-2871187
If you are anyway gonna change it, just take it with you to store. All batteries have their technical details listed somewhere. On those button sized they are either on top or bottom.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/211446-motherboard-battery/#findComment-2872160
