After a solid fortnight of abuse I'm going to get rid of the Biostar TA970 motherboard I bought for my budget gaming build. I'd like to replace it with something that is cheap, does have a USB 3.0 header and is compatible with a FX6300 and a Sapphire R7-265 graphics card.
I won't be overclocking and I'm new to PC building so ease of use would be nice.
Thanks in advance.
https://linustechtips.com/topic/211131-motherboard-advice/
The GA-970A-UD3P would be a great option because it has USB 3 in addition to a high-quality 8+2 vrm design that is sure to stand up to anything an FX 6300 can throw at it.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2865806
Gigabyte, Msi, Asus. any board from those manufacturers should do you well.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2865810
ASRock boards are very good also, and usually less money :)
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2865851
I think you mean "take from it"
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2865855
Ryan, I noticed your picture. I'll also be using that case :)
How much is that board
I love the Source 210 :wub:
The mobo can be found around $80: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2865908
https://linustechtips.com/topic/211131-motherboard-advice/#findComment-2866267
