NEED HELP! (virus n stuff) :3
Go to solution Solved by Lumi,
yes, you can. You can also get them through .pif's.
Also the guy saying jpegs, lol no. You can't bind a virus to an image file because it won't run when windows photo viewer opens, it'll just corrupt the image and make it not view able.
If you ran it PM me on here and I can get on TV with you and remove it. Also change your steam account information immediately. Oh and give me the URL personally so I can null route their server.
Can you get a Virus (or Something) over a file that ends with .SCR ?
Windows says its a screensaver but i got this file from a (confirmed) scammer in steam So yeah.
if anyone knows a lot about such stuff pls help!
You can essentially get a virus from any format of file...
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
Unless you asked for the file, It's probably malware :(
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
Yes.
Some programs to help you:
malwarebytes
bitdefender (use the trial of it's best security)
ccleaner
regcurepro
advanced systemcare
spyware terminator
zemana antilogger (just in case it installed a keylogger)
winpatrol
any registry and .dll fixer
These are some of the many programs I use AT THE MOMENT.
Samung Tab S 8.4
i want to die
I Guess that solves my Problem :D
TY!
TY!
glad i could help. Also people who make this malware are generally newbies so really just open regedit and navigate to  HKEY_CURRENTUSER > software > microsoft > windows > run
Then look for anything suspicious.
i want to die
Apprantly you have never heard of ADS. You CAN get viruses from jpegs, its happened before. ADS(or alternate data streams) are just one of the ways you can do that. Granted that technique isn't as effective as it was in past years, but it is still on method. Plus you don't know what other viruses the user could have. If they were infected with a virus that modified the registry to cause all jpegs to be scanned by a malacious exe(EXTRK.EXE is one example of such), then jpegs can be a source of transmission.
I am whatever I am.
Apprantly you have never heard of ADS. You CAN get viruses from jpegs, its happened before. ADS(or alternate data streams) are just one of the ways you can do that. Granted that technique isn't as effective as it was in past years, but it is still on method. Plus you don't know what other viruses the user could have. if they were infected with a virus that modified the registry to cause all jpegs to be scanned by a malacious exe(EXTRK.EXE is one example of such), then jpegs can be a source of transmission.
too bad that's not how ADS works at all sir.
i want to die
Threres apparently a WINRAR Bug...
If you put the file in to an archive and then open it from there...
then there will be no Administartor information (or however its called) and you will open the file directly with no veryfication!
This happend to me ^^
Now a russian dude stole me CS:GO items that are worth arround 50 Euros xD
Shit but i dont care! (well i lost 50 Euros)
Because i allready Fromatted my SSD and Installed Windows again so everything should be save again :3 (+ All Passwords are now changed)
Yeah those guys are dicks. I always null route their shitty web servers to help protect people but they're so persistent.
i want to die
you can send viruses trough any file even jpeg
No you can't. A virus in a jpg would never run. Yes you would have the virus, it would make the image a little larger, but it would Never hurt your computer in any way. Viruses are only dangerous when they are run. The purpose of a virus is to run code that the creator made. For files other than exe and bat the virus would have to hack the program you use to run it which isn't very common with auto updating programs.
Once the image is processed the virus will be set free not open processed.As i said any type or file
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
Also to you
A JPEG is a file can get infected. However, in order to activate the virus, the file must be run. As the JPEG file is an image file, it will not be executed as long as the image is not processed by any other type of program.
Hence, if the image is executed by a program like a library or a database, the system can get infected.
Also to you
no. you're also incorrect. image files and executable's are 2 completely different types of data.
i want to die
Do some research and you will understand
http://www.symantec.com/security_response/writeup.jsp?docid=2002-030110-3845-99&tabid=2
There are many types of this kind of viruses
I'm sorry are you stupid?
You just linked me a thread about a virus that over writes files. not a virus that is originally stored and ran from an image file.
i want to die
