http://www.amazon.com/Fantom-GForce3-Aluminum-External-GF3B2000EUA/dp/B00CR9Q7H2/ref=cm_cr_pr_bdcrb_top?ie=UTF8
So, does anyone know which drives Fantom actually uses inside these? The RPM isn't listed, but the Pro line advertises 7200 RPM, making me think this is 5900 RPM. Can anyone confirm/deny if these drives are Seagate/WD and the speeds they run at?
Software Engineer for Suncorp (Australia), Computer Tech Enthusiast, Miami University Graduate, Nerd
https://linustechtips.com/topic/210620-missing-drive-specs/
I'd e-mail the manufacture for that but most never want you to know what exactly is inside because they use the crappiest drives on the market to make the highest possible profit with your purchase.
Its best to buy an empty enclosure and then the best drive that will satisfy your needs, may cost more but you'll get exactly what you want not some random drive.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/210620-missing-drive-specs/#findComment-2862137
