Hi, I just set up my 2nd 780 and I lost all audio except my monitors, could someone please help?!?!? I have speakers and device manager says they're working as they should be but it also says that they're not connected despite the fact that they are connected to the 7.1 audio connectors in the motherboards rear IO
https://linustechtips.com/topic/209981-please-help/
You have to figure this kind of problems by yourself because we don't know how they are connected or what you have down there.Check the audio control center may be some wrong settings
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/209981-please-help/#findComment-2849991
I assume you are using a hdmi port for the monitor right?
make sure the analog audio is selected big chance its sending audio to digital
https://linustechtips.com/topic/209981-please-help/#findComment-2849995
