Zip ties for securing fan?
Go to solution Solved by X1XNobleX1X,
Is it safe to zip tie a fan in place where it's not meant to be a fan, like the 5.25" drive bays?
It's a bit ghetto, but it would work.
Is it safe to zip tie a fan in place where it's not meant to be a fan, like the 5.25" drive bays?post-57327-0-84380100-1409903809.jpg
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/209944-zip-ties-for-securing-fan/
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
Yea, its perfectly ok, just make sure it is secure, get it really tight, and make sure it is not in the way of anything.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
Yup, done it. Magical stuff.
Ok, thanks. Will do that then.
You can, but you will probably get  sound emanating from that area due to vibration.
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
if you do a getto solution you could add some softfoam to reduce vibractions too. And every tight connection with the case will transport vibrations, no matter-what.
Personal experience?
Police uses it too :D
Java Programmer, AMD Fanboy and soon to be casemodder
