Problem with my CPU?
I have i5-4690k at stock speed, raijintek aidos cpu cooler,z97 motherboard,asus gtx 780,evo 840 250gb.8gb corsair vengeance pro 2133mhz cl9,etc.
I id perfomance test 8.0,and everything seems great,(even 8gb of my ram has better score then 16 gb of G skill),but there is problem with CPU.
It seems to get worse score then i7-3770k
Info about my cpu from that test:
Here is more details about CPU test
http://prntscr.com/4jrrlv
http://prntscr.com/4jrrrw
http://prntscr.com/4jrrwa
I was thinking that overall it should be faster then 3770k at stock speed.
There was almost no programs ot anything that would cause cpu to work slower.
https://linustechtips.com/topic/209799-problem-with-my-cpu/
It seems to get worse score then i5-3770k
no, the 3770K is a superior CPU to the 4690K
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847602
-Snipe-
Well, I'm unfamiliar with the test, but keep in mind that your CPU doesn't have hyperthreading, and is still a small bit worse overall in most tasks than a 3770k due to hyperthreading, and maybe some other differences within the architecture.
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847611
There is no i5 3770k. There is only i5 3570k or i7 3770k.
And i7 3770k (as seen in the benchmarks) will definitely beat your i5
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847648
A 3770k is an i7 not an i5
ahh good point i didnt noticed the OP called it the i5-3770K, he did not realised it was an i7 thus making it faster...
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847649
Sorry guys it is late here,and I automatically was thinking that it is I5 for some reasons. I know there is no i5-3770k,but I didnt saw it :D
thank you,everything seems ok then,I will just clock it to about 4.0ghz so I get even more speed.
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847714
I was thinking about i7-3770k,but for some reason I thought it is i5,even if there is no i5-3770k. It is 3am here so maybe that`s why
Do not fret, if you are gaming then your cpu is still superior to even the 3770k. If only slightly.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847767
Right now I am playing far cry 3,I had trouble with playing minecraft before on old computer. I was getting 20fps,where now when I look in sky I get 3365 :D
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847782
If only a 3rd party programmer made a software program for creating additional threads or virtual CPU's to enhance threading where its needed.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847792
Treat you cpu like it should be. Overclock it. It's devils canyon. You should not have trouble hitting 4.2Ghz on a stock cpu if you don't have...more exotic cooling.
https://linustechtips.com/topic/209799-problem-with-my-cpu/#findComment-2847883
