Hello all, i want to create a 450 dollar PC build that can play games mainly like Dota 2, Skyrim,MMOs and other games with friends, i also want to use this tower for schoolwork as im going to be a freshmen in college soon.
any advice? what kind of rigs/parts should i get as i was hoping i could squeeze dual monitors because my sister who was in my major recommends
them.
TL;DR:
want a pc build for around 450- 550  that can play most titles at 1080p at high, or meduim, as well as good recommendations for monitors that wont pass  650 in total.
Building a PC: check it out here http://pcpartpicker.com/p/1qvon
https://linustechtips.com/topic/208291-450-usd-build-possible/
them.
TL;DR:
want a pc build for around 450 that can play most titles at 1080p at high, or meduim, as well as good recommendations for monitors that wont pass  650 in total.
There is no way you will be playing games like skyrim on high 1080p, If I were you I would try to save up more money because $450 is nothing.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825835
Its possible.
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825848
Here
PCPartPicker part list: http://pcpartpicker.com/p/W4T88d
Price breakdown by merchant: http://pcpartpicker.com/p/W4T88d/by_merchant/
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($166.98 @ OutletPC)
Motherboard: Gigabyte GA-F2A88X-UP4 ATX FM2+ Motherboard  ($79.99 @ Micro Center)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory  ($86.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  ($94.99 @ NCIX US)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($34.78 @ Amazon)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $498.72
Generated by PCPartPicker 2014-09-01 18:44 EDT-0400
When you're ready for 1080p gaming, throw in a GPU. A 270X is the best cheap card for 1080p for the most part. But for now, you'll have your MOBAs playing great....and Skyrim at 720p.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825850
if you are looking to play 1080p high-medium settings you might want to bump your budget to 650 minimum.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825853
Its possible.
yeah, at 2fps
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825865
yeah, at 2fps
If my $300 laptop can run it on medium with 70+ mods at 40+ FPS then a $500 build can do it too.
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825878
Dual monitors is not necessary but if you need/want them, here's pretty much the best build you're gonna get.
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor  ($79.49 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ NCIX US)
Motherboard: MSI A55M-E33 Micro ATX FM2+ Motherboard  ($44.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($72.00 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($48.99 @ Amazon)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card  ($134.99 @ Amazon)
Case: Rosewill FBM-02 MicroATX Mini Tower Case  ($22.99 @ Amazon)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($43.99 @ Newegg)
Monitor: Gateway KX2153 Abd 60Hz 21.5" Monitor  ($89.99 @ Newegg)
Total: $657.41
Generated by PCPartPicker 2014-09-01 18:49 EDT-0400
With only one monitor there's this build.
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($199.99 @ NCIX US)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($34.99 @ Micro Center)
Total: $644.42
Generated by PCPartPicker 2014-09-01 18:51 EDT-0400
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825882
-snip-
Here you go:
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($59.99 @ Micro Center)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($99.99 @ Amazon)
Video Card: EVGA GeForce GTX 750 Ti 2GB FTW ACX Video Card  ($149.99 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($46.98 @ Newegg)
Total: $553.92
Generated by PCPartPicker 2014-09-01 18:53 EDT-0400
https://linustechtips.com/topic/208291-450-usd-build-possible/#findComment-2825898
