Hello! I am not new to LTT, I just decided to become less of a lurker and a better poster and all that stuff. I was wondering what I would need/ have to do for custom loop watercooling. What parts/ fittings would I need to have? Time is not a problem, but money is. I was thinking at around $500, I could get it done. Is that true? This will be for my build "Project Ashley". The pictures don't do it justice, You would have to be there. A blue theme as you may notice, I need to know anything of help, Thanks!   -Me
Ps: This project probably wont even start for 6 months, when I earn enough money for this.post-123438-0-42152700-1409603841_thumb.post-123438-0-26984400-1409603846_thumb.post-123438-0-56815700-1409603851_thumb.post-123438-0-50802200-1409603857_thumb.post-123438-0-33184400-1409603862_thumb.post-123438-0-71082100-1409603864_thumb.post-123438-0-82269800-1409603866_thumb.post-123438-0-20393500-1409603869_thumb.post-123438-0-69773000-1409603877_thumb.post-123438-0-31532700-1409603882_thumb.
post-123438-0-21564400-1409603871_thumb.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/208230-custom-loop-watercooling-help/
I would upgrade to 8gb's and a better graphics card before watercooling. if it's just the cpu than a Swifttech h220x would be great than you can upgrade later.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
:D creeper! :D
are you sure you want to spend $500 on watercooling instead of getting 2x better performance?
I agree with the above posts. Your build is kinda imbalanced. Overkill CPU, only 4gb of ram, and quite an old GPU. In your case I would upgrade my GPU first, unless you're satisfied with the performance of course.
Also, €500 is a good budget for watercooling imo. You can get a nice loop going with that.
Edit: Also noticed you only have 250GB HDD? What do you use your PC for? o O
It is said, that civilised man seeks out good and intelligent company, so that through learned discourse he may rise above the savage and closer to God. Personally, however, I like to start the day with a total dickhead to remind me I'm best!
Well, the thing is, I REALLY like the look of custom watercooling, as for the 250 gig hdd, that is beacuse i caried that over from my other build. I got it beacuse it was cheap, and I was able to get my pc running quick. (I havent used over half yet).
:D creeper! :D
I just like the look of custom loop cooling. And I am willing to spend $$$ on it.
i think i priced a wc build out for myself and it was 700$ all in
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
ok then :)
look at SingularityComputers on youtube and you will learn everything you need to know before building your own custom loop
ok then :)
Thanks! Ill do that!
