Any 2011 Cooler will fit.
So go with some liquid cooler like H105 or better Swiftechs H series.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/208013-2011-3-cooler/#findComment-2821942
you gonna overclock? if so something like the kraken x61 will be great or if you dont have room for  280mm a h100i is pretty good
I'm gona overclocked that and in the 900d am sure that a 280mm fits. I was thinkink something like h220-x what do u think?
https://linustechtips.com/topic/208013-2011-3-cooler/#findComment-2821954
bequiet Dark Rock 3 Pro and Noctua NH-D14/15 would be good air coolers and still sufficient for LGA 2011.
Why a 900D? :D
With that case i would recommend a custom water cooling loop, otherwise it's just wasted space.
who cares...
https://linustechtips.com/topic/208013-2011-3-cooler/#findComment-2821956
i do not like air coolers that much
Why a 900D? :D
Actually that not mine is a order from there i do work and my customer wants these so i cant say no. He just suggest me a good cooler for his rig. And i will overclock his cpu
https://linustechtips.com/topic/208013-2011-3-cooler/#findComment-2821961
Which cpu cooler do u suggest my for my new 2011-3 cpu?
If you're a owner of any of the recent Noctua heatsink cooler(s) you can request a new mounting kit with proof of purchase. Not really sure whether the original 2011-0 is compatible with the rev3.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/208013-2011-3-cooler/#findComment-2822021
