I'm designing a test bench as a project and I've been looking around for atx specifications, but I can't seem to find up to date ones anywhere.
I'm planning on having the mounting points for atx and micro-atx boards. I just need the specs for the mounting holes, if anyone knows where to find it.
CPU- 4690k @4.5ghz / 1.3v    Mobo- Asus Maximus VI Gene   RAM- 12GB GSkill Assorted 1600mhz   GPU- ASUS GTX 760 DCUII-OC
Storage- 1TB 7200rpm WD Blue + Kingston SSDNow 240GB   PSU- Silverstone Strider ST75F-P
https://linustechtips.com/topic/207868-atx-specifications/
Why not just take a look at a case?
If I can't find specs I will, I'd just like to have the formal/exact measurements for it.
https://linustechtips.com/topic/207868-atx-specifications/#findComment-2820126
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/207868-atx-specifications/#findComment-2820141
Because I totally didn't check that already. -.-
I need something with the exact locations of the mounting holes, not just the physical motherboard sizes.
https://linustechtips.com/topic/207868-atx-specifications/#findComment-2820180
best way is to pick up an atx board from the tip and mark the holes yourself.
https://linustechtips.com/topic/207868-atx-specifications/#findComment-2822115
