This is my build: http://pcpartpicker.com/p/LBm6NG
Give me all suggestions and criticism on my rig please.
I'm gonna go with a green/black color scheme, which you can tell from my peripherals.
1. Budget and Location
I live in the U.S. My absolute maximum price point is $4,000, but as you can see in the parts list I tried to keep it lower than that.
2. Aim
I'm gonna use this computer for video editing, graphic design, and some web browsing. But my main use for this rig will probably be for gaming. All games.
3. Monitors
I plan on running 3 24 inch monitors (suggestions?). Maybe 3 27 inch monitors (like the PB278Q) if prices go down.
4. Peripherals
Keyboard: Corsair Vengeance K70 RGB OR Razer Deathstalker
Mouse: One of the razer mouses, not sure which
Headphones: Razer Kraken
OS: I'm planning on waiting for Windows 9 or getting Windows 7
5. Why am I upgrading?
My computer is 8 years old. It's crazy slow, can barely handle 10 tabs in chrome, and it's showing a lot of signs of dying.  I run games at about 7 fps (i tried to play slender once and it looked like a  slideshow)
https://linustechtips.com/topic/207125-first-build-plan/
Why did you chose those gpu's?
but here's a build
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.98 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Newegg)
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  ($157.50 @ Newegg)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($144.99 @ Micro Center)
Video Card: Diamond Radeon R9 290X 4GB Video Card (2-Way CrossFire)  ($449.99 @ Micro Center)
Case: Corsair 760T White ATX Full Tower Case  ($169.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: LG 29UM65-P 60Hz 29.0" Monitor  ($349.99 @ NCIX US)
Mouse: Razer DeathAdder Wired Optical Mouse  ($55.99 @ Amazon)
Headphones: Razer Kraken 7.1 Channel Headset  ($69.99 @ Newegg)
Other: K70 RGB ($169.99)
Total: $3887.30
Generated by PCPartPicker 2014-08-30 19:06 EDT-0400
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810417
@Spudds This build is only a little bit more expensive but leagues faster than what you posted.
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler  ($89.98 @ OutletPC)
Motherboard: Asus Z97-AR ATX LGA1150 Motherboard  ($149.99 @ TigerDirect)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory  ($159.99 @ NCIX US)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($118.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($99.00 @ Amazon)
Video Card: Sapphire Radeon R9 290 4GB Vapor-X Video Card (2-Way CrossFire)  ($449.99 @ Newegg)
Case: NZXT Phantom 630 (Black) ATX Full Tower Case  ($174.98 @ SuperBiiz)
Power Supply: EVGA 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($154.99 @ Amazon)
Total: $2177.88
Generated by PCPartPicker 2014-08-30 19:04 EDT-0400
Because everyone sees they're faster than a 780 or 780 Ti in a perfect scenario and go "Oh! These are cheaper and perform better!" when in reality it's one of those terrible computer sins you can do.
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810431
get a GTX 780 and put them in SLI or an R9 290 and crossfire them
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810432
2. Aim
3. Monitors
4. Peripherals
Those graphic cards are so full of no.
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810449
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard  ($238.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($140.98 @ Newegg)
Video Card: Asus Radeon R9 295X2 8GB Video Card  ($1557.04 @ Newegg)
Case: NZXT Phantom 820 (Black) ATX Full Tower Case  ($234.98 @ Newegg)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  ($277.58 @ Newegg)
Headphones: Razer Kraken Headphones  ($59.99 @ Newegg)
Total: $3892.49
Generated by PCPartPicker 2014-08-30 19:19 EDT-0400
Generated by PCPartPicker 2014-08-30 19:15 EDT-0400
If you don't want the dual gpu card pick up a couple of 290xs.
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810513
@Spudds,
While the GTX 760 in SLI have better gaming performance it is not that much better than the slightly less expensive R9 290X. Your editing software may not take advantage of dual gpu or only use both of them for particular operations.
I would also suggest a better cpu cooler and less expensive motherboard and memory.
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($136.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory  ($137.99 @ Amazon)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($513.98 @ SuperBiiz)
Case: NZXT Phantom 820 (Black) ATX Full Tower Case  ($213.86 @ Amazon)
Power Supply: be quiet! Dark Power Pro 10 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($199.99 @ NCIX US)
Total: $1890.77
Generated by PCPartPicker 2014-08-30 19:21 EDT-0400
https://linustechtips.com/topic/207125-first-build-plan/#findComment-2810591
