Boot Device LED stays on
Go to solution Solved by Archangel1994,
That sounds like a bad board if it worked for a moment after leaving it for a bit. You could try resetting CMOS (Doubt it will do anything though) and removing any drives you do not need (the non-OS Drive, the blu-ray drive). Also try swapping out your graphics card for a different one (maybe borrow from your friends or something). If you still BSOD after this then I smell a bad board.
Estisting system.  Asus Sabertooth 990FX, FX6300, SATA drives (2 SSD and one HDD), and a internal bluray drive.  The system has been stable for 4 months.
Today, it locked, blue screened and rebooted.  It could not find the the boot drive.  I booted into BOIS and the only drive the system saw was the bluray.
I walked away and let it sit, rebooted, and it saw all of the drives.  Launched Win7, and it locked/BSOD again after a few minutes.  Rebooted into BOIS, and it saw some of the drives, but not all.
Reflshed the BIOS, no change.
Anything posabiliies other than a bad board?
chad
https://linustechtips.com/topic/207002-boot-device-led-stays-on/
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/207002-boot-device-led-stays-on/#findComment-2808667
verify power to drive(s)
verify data cable connections
assuming the SSD (possible RAID) is holding the OS?
SATA controller sounds flaky if all connections are proofed.
try different SATA ports to see if problem moves with the port swap, if so, the
controller is dumping. unless the PSU isn't supplying voltage to drive(s).
https://linustechtips.com/topic/207002-boot-device-led-stays-on/#findComment-2808676
Maybe a bad motherboard or just a bad SATA controller? Do what @airdeano said to check them all.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/207002-boot-device-led-stays-on/#findComment-2808722
Replaced the MB, and a HDD. Problrm solved, unfortunately.
Thanks
Chad
https://linustechtips.com/topic/207002-boot-device-led-stays-on/#findComment-2823304
