noctual fans
Go to solution Solved by jaffacakes,
i've been looking at the noctual fans and they have quite a few "functions":
  • NF-F = Focused Flow
  • NF-A = Air Flow (Case fan)
  • NF-S = Silence (Aimed at nothing but silence)
  • NF-P = Pressure
  • NF-R = Raised blade
  • NF-B = Beveled blade
what all this mean and what are they for?
Focused flow = More for smaller areas, like infront of the HDD cage or in rads.
Air flow = More for letting air go around the case, general cooling.
Silence = Air flow based but at a lower rpm for more of a silent rig
Pressure = Mostly rads.
Raised blade = For small and low rpm fans so that they are more effecient
Beveled blade = Between Air flow and Silence.
What's noctual?
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
https://linustechtips.com/topic/206848-noctual-fans/#findComment-2806760
  • NF-P = Pressure
https://linustechtips.com/topic/206848-noctual-fans/#findComment-2806764
  • NF-F = Focused Flow = direct airflow feature that gives better airflow direction and static pressure when the fans are mounted in push
  • NF-A = Air Flow (Case fan) = less static pressure, better for placement where there are no to minimum airflow restrictions
  • NF-S = Silence (Aimed at nothing but silence) = true, not worth it tho because the fans spin at really low rpm making them pretty shitty
  • NF-P = Pressure = older versions of the NF-F class fans, they still perform great, a good bargain if you can get em cheaper
  • NF-R = Raised blade = dunno
  • NF-B = Beveled blade = dunno
Edit: damn it got  :ph34r: 'ed
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/206848-noctual-fans/#findComment-2806771
