Upgrading audio. Is it worth it?
Go to solution Solved by SeanBond,
Sennheiser game one? Why? Get the 363d with a integrated sound card. You won't have to buy a sound card. However I did just look at pricing and it went back up, I bought it last month for 230. Try looking for it at that price.
Hello guys,
Currently im using a Corsair Vengeace 1500 headset with its integrated usb audio. Im thinking of buying the Sennheiser G4ME ONE with an Asus Xonar Phoebus. The thing is, this would set me back about GBP320 and im not sure that the difference in quality would justify that. What do you guys think?
CPU: Intel i7 3770k + Corsair H105 Motherboard: ASUS Sabertooth Z77 Memory: Corsair XMS3 8Gb 1600Mhz VGA: ASUS GeForce GTX 780 Ti Matrix PSU: Corsair AX860i
Storage: Samsung 850 Pro, OCZ Vertex 4 128Gb, WD Green 2Tb Case: Corsair 760T Monitor: Acer Predator XB1 + LG IPS234
https://linustechtips.com/topic/206735-upgrading-audio-is-it-worth-it/
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
the game ones and 363s are essentially the same thing and that usb card is kinda meh buddy of mine has it we both prefer the aging DX
@Kloaked sure, im open to suggestions thats why im here. I had a look at the FiiO, does this have any sort of software included? Equalizers and whatnot.
Keep headset for headset use. You dont need that ultra clarity that people claim that is essential in competitive gameple, but thats not the case. As long as you get certain range of sounds delivered to you, and you can pick up on that, thats all you need. Heck, play around with EQ if you need to.
Anyway, if you want to 'upgrade' audio, I would suggest you to get a good headphone, and either choose desktop/pro mic. Modmic is good and all, but over-hyped. The only real reason why you would want to use modmic instead of desktop/pro mic is if you want to use voice activation mode in softwares like vent or mumble. But modmic is too sensitive for this so that even a slightest bump on the modmic cable or rapid keyboard/mouse clicking will activate voice activation, making it essentially a push-to-talk mic. If thats the case, you might as well get a 'proper' mic, and that way you can sound much more clear (current modmic, modmic 4.0 iirc, is slightly muddy).
Anyway, TLDR, get headphone + desktop/pro mic, if you want to upgrade your audio.
